Insert bit with 1/4" hex drive Designed to be used with screwdriver-type hand tools S2 modified tool steel and heat treated to 58-62RC Process for gauge fit, tolerance and specification accuracy
Store | Price |
ToolKing.com | [show price] |
I love all Forney products, they are gentle to use and the prices are fantabulous . Especially Forney 70862 Insert Bit Torx with 1/4 Inch Hex Drive T20 by 1 Inch 2 Pack is terrific just for 9.59.
