Cables To Go 03148 6ft MONITOR POWER ADAPTER CABLE (NEMA 5-15R to IEC320 C14)
Plug in the UL-listed Monitor Power Adapter Cable from Cables To Go to make your work environment more flexible and efficient. All Cables To Go power cables feature a fully molded design that provides maximum durability and long life. Cable Type: Heavy-Duty 18AWG. Connectors: 3-pin Shroud Male to 3-Prong Grounded Plug Female. Design: Female connector plugs directly into device and male connector plugs into existing cable. Compatibility: Monitors. Application: Female connector plugs into device and male connector plugs into auxiliary power port on power supply for auto power when the system is turned on. Rated: 10 Amps. Certification: UL Listed.
Click for Best Price »
Price comparison
Store Price
CompSource [show price]
UnbeatableSale.com [show price]
Cables To Go 03148 6ft MONITOR POWER ADAPTER CABLE (NEMA 5-15R to IEC320 C14) Review
When you are looking for fast and special cables & connectors #3, that is something for you. Nothing is better at this particular 15.56.
Read more reviews »
