Pro-Audio Cables from Impact Acoustics are made from twisted pair audio cable under an aluminum foil for maximum shielding from noise. High flexibility 7mm PVC jacket reduces the risk of cables kinking and damaging the conductors. Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Spring strain relief on the plug reduces the effects of age on the solder joints and contacts. Features: 22AWG Twisted Pair construction. Foil shield and 60% copper braid. Nickel plated brass connectors. Tip/Ring/Sleeve (TRS) Configuration. Connect line or mic level outputs from mixing consoles to recorders and amplifiers with balanced inputs.
Store | Price |
UnbeatableSale.com | [show price] |
TigerDirect | [show price] |
I had been using Cables To Go 40072 3ft PRO-AUDIO CABLE 1-4in TRS MALE to 1-4in TRS MALE for quite a while now and I must say, I love it. I read many reviews for this product by C2G and I definitely didn't make any mistake.
